Messy Harley-Davidson Oil Filter Change No More!
Accessories & Modifications On/For Road Glides. Share that find!
Post Reply
User avatar
L2
Has thanked: 128 times
Been thanked: 94 times
Contact:
Post: # 128Post L2 »
Messy Harley-Davidson Oil Filter Change NO MORE!
I've been using this same gear oil quart canister for years.
Simple and cheap too! Cut the bottom of the jug even with a good razor blade, pull the front shift linkage (on the new Center Cooled bikes it's a little easier if you take a few seconds and unscrew the nut on the back of the horn too), keep it on the kickstand so the oil drains into the cannister. Don't use a wobble extension either, just a straight 3/8" extension.
The cannister with the 3/8" extension through the center connected to the oil filter tool allows the oil to gravity flow into the cannister when you loosen the oil filter (hold the entire contraption up against the engine while loosening). Let it sit for a few moments when you feel the O-ring pull away from the engine (gets super easy to turn). That lets the oil pool in the cannister and NOT all over your bike frame and floor. Easy to put in the drain pan now with no oil on the floor!
L2
BDM
Has thanked: 18 times
Been thanked: 22 times
Re: Messy Harley-Davidson Oil Filter Change No More!
Post: # 197Post BDM »
Damn good idea, ive used a half gallon of milk, this looks to be a better fit.
Jerrol
2018 FLTRX Wood 22x/Sidewinder/HPI Manifold/tunes/bars… damned expensive derby cover..
User avatar
AJRock
Has thanked: 26 times
Been thanked: 15 times
Post: # 202Post AJRock »
BDM wrote: Mon May 19, 2025 3:17 pm Damn good idea, ive used a half gallon of milk, this looks to be a better fit.
I did the same. It's time to upgrade to the quart-size round oil container, LOL!
Andy
2016 RG Ultra CVO
Post Reply
