Anybody Else Getting Codes All The Time?
For all things Center Cooled Road Glides from 2023.5 & Newer
Post Reply
User avatar
L2
Has thanked: 128 times
Been thanked: 94 times
Contact:
Post: # 53Post L2 »
Anybody else getting codes all the time?
I'm getting an ECM "communications" code over 50% of my startups now. Used to be just once in a while.
To get around it I pretty much clear the code then hit the starter button (momentarily) and start the bike and the engine light stays off. If I clear the code then shut off the ignition and turn it back on and start the bike, the warning/check engine light comes back on around half of the time.
It's getting to be a battle with the warning/check engine light.
Anybody else seeing this?
L2
User avatar
OBB
Has thanked: 19 times
Been thanked: 53 times
Re: Anybody Else Getting Codes All The Time?
Post: # 70Post OBB »
Not yet. Will be interested to see how this pans out.
OBB Aka Ohiobellboy Aka (insert your favorite adjective here) but most of all, fuck Frank!
OlYankee
Has thanked: 4 times
Been thanked: 6 times
Post: # 92Post OlYankee »
On occasion I'll get a code for "Lost communication with [some_random_module]." It happens on those rare occasions when the bike shuts itself down after attempting to crank, first start of the day. I figure it's because the power loss interrupted the boot sequence and threw a code. If it doesn't clear after 3 more starts I just clear it manually and go on my way. Bike always seems to run perfectly regardless.
Rob L
Has thanked: 38 times
Been thanked: 46 times
Post: # 179Post Rob L »
I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
User avatar
L2
Contact:
Post: # 186Post L2 »
Rob L wrote: Sat May 17, 2025 5:06 am I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
Did you undo the tie wrap binding the wires behind your coil?
L2
Rob L
Post: # 188Post Rob L »
L2 wrote: Sat May 17, 2025 4:04 pm
L2
I did. Makes no sense why they put the zip tie there
Post Reply
