Anybody else getting codes all the time?
I'm getting an ECM "communications" code over 50% of my startups now. Used to be just once in a while.
To get around it I pretty much clear the code then hit the starter button (momentarily) and start the bike and the engine light stays off. If I clear the code then shut off the ignition and turn it back on and start the bike, the warning/check engine light comes back on around half of the time.
It's getting to be a battle with the warning/check engine light.
Anybody else seeing this?
L2
Anybody Else Getting Codes All The Time?
- OBB
- Has thanked: 19 times
- Been thanked: 52 times
Re: Anybody Else Getting Codes All The Time?
Not yet. Will be interested to see how this pans out.
OBB Aka Ohiobellboy Aka (insert your favorite adjective here) but most of all, fuck Frank!
On occasion I'll get a code for "Lost communication with [some_random_module]." It happens on those rare occasions when the bike shuts itself down after attempting to crank, first start of the day. I figure it's because the power loss interrupted the boot sequence and threw a code. If it doesn't clear after 3 more starts I just clear it manually and go on my way. Bike always seems to run perfectly regardless.
I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
- L2
- Has thanked: 128 times
- Been thanked: 94 times
- Contact:
Did you undo the tie wrap binding the wires behind your coil?Rob L wrote: Sat May 17, 2025 5:06 am I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
L2
I did. Makes no sense why they put the zip tie thereL2 wrote: Sat May 17, 2025 4:04 pmDid you undo the tie wrap binding the wires behind your coil?Rob L wrote: Sat May 17, 2025 5:06 am I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
L2
