Winter Prjects Lined Up
#1
Started as one project , will be two , maybe three
1) Progressive Mono Tubes -1" , was it originally , price was right , if they don't work , I'll save up for a 49 kit , also check the trees while in there ..
2) decided to go ahead and bite the bullet and got the SE Comp Kit , this one has gone 103k , time to change it me thinks ..
3) Since I'm doing the comp , gonna eyeball the belt really good and replace if necessary , have one on the shelf , I snagged years ago from the other place for a song  .. Rear Isolators and bearings are supposed to be good "for life" whatever that is ..
Brad is sending me some widgets that fit inside the isolators for a tighter fit , if I don't have to change the belt , they will sit on the shelf till needed .. Don't know what it is with the mail service up north , but whenever I send him and Eddie and anyone else stuff that goes thru Chicago , it sits in Chicago forever , same when they send to me , hangs up there .. He sent it out Oct 26 and it's been stuck in Chicago since the 27th ..
crazy
JtB
So Many Highways
So Little Time
The following 4 users say Thank You to JacktheBagger for this post:
Reply
