Page 1 of 1
Anybody Else Getting Codes All The Time?
Posted: Wed May 14, 2025 11:46 pm
by L2
Anybody else getting codes all the time?
I'm getting an ECM "communications" code over 50% of my startups now. Used to be just once in a while.
To get around it I pretty much clear the code then hit the starter button (momentarily) and start the bike and the engine light stays off. If I clear the code then shut off the ignition and turn it back on and start the bike, the warning/check engine light comes back on around half of the time.
It's getting to be a battle with the warning/check engine light.
Anybody else seeing this?
L2
Re: Anybody Else Getting Codes All The Time?
Posted: Thu May 15, 2025 2:20 am
by OBB
Not yet. Will be interested to see how this pans out.
Posted: Thu May 15, 2025 10:54 am
by OlYankee
On occasion I'll get a code for "Lost communication with [some_random_module]." It happens on those rare occasions when the bike shuts itself down after attempting to crank, first start of the day. I figure it's because the power loss interrupted the boot sequence and threw a code. If it doesn't clear after 3 more starts I just clear it manually and go on my way. Bike always seems to run perfectly regardless.
Posted: Sat May 17, 2025 5:06 am
by Rob L
I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
Posted: Sat May 17, 2025 4:04 pm
by L2
Rob L wrote: Sat May 17, 2025 5:06 am I posted on the other forum regarding the check engine light that popped on when it ran on one cylinder for about 10 seconds on a ride I was on while it was raining. CEL was on but there were no codes present. I tried several times to clear the light but it would clear until I removed the main fuse and left it out overnight. Hasn't come back on since
Did you undo the tie wrap binding the wires behind your coil?
L2
Posted: Sat May 17, 2025 8:52 pm
by Rob L
L2 wrote: Sat May 17, 2025 4:04 pm
L2
I did. Makes no sense why they put the zip tie there
